Can any one tell me what gas and what weight of that gas should be in my air con system?
I’m getting it done at work by the fridge shop but they need to know these details also is there a max pressure the system can take as he is going to pressure test it with nitrogen first to make sure there is no leaks.
The connections on the air con pump are push fit connections is this anything to do with the gas conversion that the car might have had????
Finally is there any way to tell what mod’s the system might have had done to it to accommodate the new gas????
