anyone put on a larger diameter exhaust on a 1990 surf? if so, what did you go with and what were the results?
The general concensus seems to be that a 2½" system, preferably mandrel bent is the one to go for. You can lose the back box as it is only a resonator and just have the main box between the axles. Some people recommend a short length of 3" pipe from the turbo but that's personal preference. The easy way to do it would be to modify and fit the system from a 3ltr as the only difference is the front pipe.Originally posted by d rockanyone put on a larger diameter exhaust on a 1990 surf? if so, what did you go with and what were the results?Roger
