I recently overheated my 1989 Hilux. The head in the 2 LT engine was cracked. I ordered a new head which comes without valves. I've talked to a few mechanics and they advise I can't simply stick my old valves into the new head. Does anyone have advice/experience with this?
Replacing head - Valves???
Originally posted by strummerI recently overheated my 1989 Hilux. The head in the 2 LT engine was cracked. I ordered a new head which comes without valves. I've talked to a few mechanics and they advise I can't simply stick my old valves into the new head. Does anyone have advice/experience with this?If it aint broke dont fix it
Originally posted by gary16163you will need to clean the old valves up then lap/grind them in to the valve seats to create a good seal, this is a fairly simple task I suggest you search the web to see how to do this, then once this is done you will need to reshim the head for correct valve clearences
and oil seals.
I always buy built heads, the extra cost vs time to check/clean/lap/set shims/etc... isn't really a saving IHMO.
But seeing as you've got to do it, clean all the carbon off the valves, check they are straight, check they fit the guides OK, then you can fit new guide seals, fit all the valve springs and cam, then set the valve lash.
If you need all the specs, I can get them later.
