Hi all,
I need some help on how to get the 19mm nut undone on the crank pulley.
Manual says" remove flywheel inspection plate and lock flywheel with screw driver"
I don't seem to have a fly wheel inspection cover.
How can I stop the movement in the engine? ( have tried putting it in gear-didn't work)
I've already got all the drive belts off so I need to lock up the engine.
Thanks.
Clive.
Thanks.
Clive.
