How easy?
  • How easy?
    Hello fellow surfers.
    Is it easy to check and then adjust the valve clearances on a 2.4 2LTE engine.
    Also, are there any special tools needed or will regular spanners/sockets etc do the job.
    Anyone want to offer a step by step guide would be gratefully received!
    I'd like to have a go unless I run the risk of killing my car!
    Cheers, Matt
    You aint seen me, right
    Anyone?????
      Never done it but I think it's a complicated job as the valve clearances are set with shims.
      Roger
        valve clearances
        Hi,
        You need a valve lifter/compressor tool, adjusting shims and a feeler gauge.
        It is fairly straightforward to `check` the clearances by using the TDC marks on the crankpulley to line engine up. The harder part is removing the old shims and replacing with new. Cold engine clearances. Intake 0.20-0.30mm. Exhaust 0.40-0.50mm
        If you are keen on doing it & there is no further info. on this site, I can scan in the page from the manual and email it to you.
        cheers,
        chris
        Powered by Toyota!
          Thanks for your replies guys. I think it's gonna be something that I leave to the experts! Thanks for the advice though, much appreciated.
          Matt
