Cos I've just changed my plugs, and number 3 cylinder had about 3/4 inch missing from the end of it, and looks well burnt out.
A few weeks ago, I heard a bit of clatter from the top end of the engine, wondered what it was, so switched off, checked the oil level, all was well, and I had to get to work, so it was started up (it started fine) and drove to work. No clatter.
Now, recently, possibly since about the same time, it's been a tad troublesome to get going in the mornings. Not surprising, really, if a glow plug was bu**ered.
I did an oil and filter change a couple of weeks ago, to eliminate the thought that it could be a dirty air filter causing the dodgy starting.
Anyway, what damage am I likely to have done?
It still seems to run ok, but there is a bit of smoke on start up. White and black smoke.
Oil and water levels haven't dropped at all.
