we took our truck in to have the fuel pump sorted the bloke who is supposed to be doing it is a freind of a freind anyway cut a long story short we said right whilst its in can you do the brakes,cv boots ,new timing belt etc main reason it went in is because we were having trouble starting the truck and it was not the glow plugs then we noticed the pump leaking from the bottom end.well now the bloke reckons the pump is not leaking he says the timing belt has never been changed before even though it was supposed to of been changed when we bought the truck a few years back which doesnt suprise me, he says we have a leak in our radiator even though the water level has never dropped and there is a leak on our turbo which is why there is an area of black oil in there im guessing the bloke doesnt want to touch the fuel pump ,right fine no problems i will sort it myself $$$$$$ typical just means i will be stuck withought transport for a little longer but what about the rest?ok after writing all that i just spoke to dh again and i misheard its not the servo its the turbo its leaking from i thought i had not had any brake problems and was wondering where all these things were coming from
.ok right so can somebody tell me how big a job is it to do the turbo?can it be done or will i need to buy a re con?its one thing after another at the moment
