Having probs with my '93 2.4 diesel. Having obtained the fault code it is reading 12 which is the Timer Control Valve (Pump). I have recently had the pump replaced and I am assured that the timing is correct. The strange thing is that it runs a treat for about 40 minutes (give or take) then it starts to clatter and the engine check light comes on. If I turn it off for a few minutes it all seems to clear and off I go again until it clatters again.
If the timings out surely it would be out all of the time. If its not the timing what on earth is it?
