radiator top hose seems to be getting quite solid after a few minutes driving - is this normal?
i haven't noticed any considerable drop in water levels, every few days after a lot of driving it may need half a cupfull of water, i think this may be due to a very slow leak though
i had the head changed two months ago, and it's a stevo one. the truck as far as the temperature gauge hasn't overheated, and the white sticker on the side of the head shows that two of the four squares have turned black
what's the reason for this pressure in the top hose...surely can't be right? even after the engine switched off, it remains solid. my mates pajero after a long run had a very soft top hose once the engine switched off
water pump and thermostat are both recently fitted. also - detect a lot of heat coming from the engine bay...dont have any surf friends to compare too - can anyone please shed some light?
and when turned off engine the hose remained quite firm
