Q1. How easy is it to change the front crankshaft oil seal? Will I have to drop the sump after pulling off the bottom pulley?
Q2. Is there anyone out there that has a 2.4 TD engine out of the engine bay? If there is, is there any chance you could pull out the "knock sensor/crankshaft sensor". I am trying to find out what the sensor is actually sensing. Is it a proximity sensor detecting the teeth on a gear being driven? Or is it a knock sensor that detects an actual knock.
The reason I ask Q2 is that I fitted an engine that does not have the hole in the block for the sensor that sends a signal to the fuel injection pump. Because of this there is no turbo boost on my truck. I have put up with this for a year but the lack of power is getting me down now. I am looking for a way of fooling the sensor, but the timing has to be correct. Maybe some of you hardened DIY masters could shed some light on this sensor. I really can not get enough money out of my wife to get a new engine (unless there is a kind chap or chapess out there that wants to swap a short engine for a short ammount of cash........) Thanks in advance.
but it's going to need sorting sooner or later.
