I have had my 1993 Surf for 3 days, Whilst on my way home from Scarborough my offside rear wheel overtook me, It is a split rim type and sits on spacers between hub and rim, all the studs sheared, any body any idea why, is it a common problem?
Rear wheel fell off
Originally posted by iwoois it a common problem?
Thos edon't look like standard surf alloys so my guess would be whoever sold it to you stuck 'em on to make it more sellable and didn't do it properly.
Phone them up and give them hell.
Originally posted by andyThe spacers are $$$$, you need the proper ones that bolt on and are made of steel.
The person who fitted em may have overtightened too - the torque settings are 103N-m (10.5kgf-m, 76 ft-lb)
TrevLook out Eastbourne, the Pandas are coming !
Phew! that's nothing too serious then.
You can order new wheel studs from here.....
http://www.milneroffroad.com/LN130.htm
wheel studs
Just out of interest, how much of the threaded stud was left in the hole (if you have managed to remove them yet). As a rule of thumb there should be 1.5 times the diameter of the stud inserted into the threaded hole. Anything longer just sticks out the back and does not add any strength, but if it is less you are putting excess stress on the stud.
I am a bit concerned because that spacers look very similar to the ones I have fitted. Where is the best place to buy the steel ones mentioned in previous threads?
Just be thankfull you were not tearing down a street at 70mph>>>>>
makes you thinkLast edited by chasharman; 2 August 2006, 18:25.
It was imported in 2004, The garage where I bought it from are sorting it out, but i suppose they will only replace what is broken.
That still begs the question about what I should do long term, replace alloy spacers? as someone has suggested with steel ones, where do you get the steel spacers from, should i go for longer wheel studs or the double fitment type already fitted.
The wheels i have fitted fitted look identical to the ones on Andys surf in the owners pics so i suppose they must have been a common fitment, as its been chucking down for 2 days I have not been able to get outside and take the thing to bits, anyway i am hoping the garage will do that.
