With engine being in bits Iam check other parts for reliability,I think Ive found Another problem waiting to happen I hope Iam wrong. My turbo has side to side movement so bad its polished its casing ie a silver band all round where the fins are on the intake side not the exhaust side.Hope this makes sense.
Turbo problems???
The only kits I've found for the turbo (CT20) is this one ...
http://www.yellow.co.nz/site/lodgeau...ir%20Kits.html
http://www.softcom.net/users/hlturbo/p/toyota.gifLast edited by BUSHWHACKER; 5 September 2006, 11:17.
Turbo Pictures
I have attached pictures of my turbo showing some of the oil on the external housing as explaine din my previous thread. I have checked the hose as recommended in a previous thread and this seems OK. Is there any other possible place it may be coming from?
Thanks
Ah, it all becomes clearer with a picture!
That's nothing much to worry about, it's just oil vapour from the crankcase breather pipe on top of the rocker cover. After a while, oil condenses and dribbles out of the rubber elbow that connects onto the turbo. Just remove the hoses, give them a wipe out, and re-fit.
Turbo
Bushwhacker, thanks for the advice. I will give the hoses a clean out.
This is a great site and find it a real help even though I have a Landcruiser (LJ70), which shares many components as the Surf. It is hard to find information relevent to the LJ70.
Thanks
