2.4 Heater Hose
  • 2.4 Heater Hose
    Can anyone who has a fuel cat fitted to a 2.4 surf please tell me what the internal dia is of the heater hose before i cut it.
    Does the hose have a 16mm or 19mm internal DIA.
    Regards
    Kev.
    2.4 black beast
    I used 5/8" hose on the other matrix hoses, which should be roughly
    the 16mm.
      the 16mm.
      Thanks mate,
      Am i also right in saying the fuel hose is 10mm as well?
      Last thing i want is to cut everything then find all are wrong sizes and have no car to drive round and change them all.
      Regards
      Kev.
      2.4 black beast
        Could be wrong, but I think it's 8mm on the 2.4, 10mm on the 3.0.
          Well the fitting on the fuel cat is 10mm
          So i just assumed the fuel line where it attaches to the fuel filter was the same
          Regards
          Kev.
          2.4 black beast
            Pull the feed pipe to the pump off the filter, and see if it fits
            on the fuel act. Easy way to check.
              Why did'nt i think of that lol
              Anyway you are right it's 8mm and NO it not fit the cat unless i heat the hose in water first.
              looks like philip is catering for the 3ltrs only on the fittings.
              Regards
              Kev.
              2.4 black beast
                Smear some washing up liquid on the fitting, then the 8mm hose might
                be persuaded to fit on the 10mm fitting.
                  Naaa, good old heat the hose in water trick should do it
                  But thanx for advice all the same m8.
                  Regards
                  Kev.
                  2.4 black beast
