I have a starting problem from cold after several seconds cranking over it will start on one or two cylinders with lots of black smoke it will eventually run on all cylinders and drives ok apart from black smoke when under load. The cylinder head was renewed at 163k and it had new glow plus/batteries and filters a few months ago its now at 180k
poor starting
Still having the same problem could the fuel be draining back to the tank? I recently changed the fuel filter but could not prime it, the hand pump is faulty I think. The only way I could get it to start was to fill the filter and crank the engine over. Are there any replaceable parts in the priming pump?
http://www.toyotahilux.com/index.php...id=135&vid=551
Sounds like you could do with new glo-plugs too!
