I'm a little concerned.
After a short drive (10 minutes) this evening i parked up and was absolutely pouring coolant out, I had driven probably a little quicker than average but not hard by anyone's standards.
Anyway when i noticed it immediately the panic set in, oh $$$$ could this be my head?
The temperature gauge was normal, bout half way. The coolant was coming out of the overflow on the expansion tank (i think that's what it is, the plastic one behind the n/s headlight), and a small amount from the cap on the other tank (the metal one with the pressure cap on a bit further back).
Up until now i've had no problems with cooling or anything like that, it's just had a full service and MOT and been running fine since i had the other problem's sorted out (gearbox, exhaust, brakes)....................... ..
It had a new engine and Rad in June 2004 from API Engines, Harbury, Warwickshire. That was at 108,070 km it's only at 120,522 now.
Could this be my head? I assume it was the head before and that's why a previous owner had the engine & rad replaced (as mentioned above).
Is there other stuff i should check before i ring Stevo?
I will have a look in the morning and see exactly how much coolant i have lost, it was just a couple of mm below the fill line mid-week when i was doing other stuff to it, so it shouldn't have just overflowed through nowmal expansion.
I'm gonna stop typing and panicking now, but any suggestions would be good.
Right...
BREATHE SLOWLY, INHALE, EXHALE etc
Right...
