I've just had my head done and I believe a recognised phase of the recovery is the paranoid bit, so please indulge me.
I drove down to my dad's place in Gloucestershire (from London) last weekend and happened to notice (because I watch it more than the road) that the temperature guage had moved about 2mm higher than normal. Normally, I can see the little picture of the thermometer, this time the needle covered it. I was probably going about 75-80 at the time so backed off a little bit and it dropped down to its normal position.
Over the weekend, I stuck a couple of vents in the bonnet and changed the rad cap and thermostat. When I drove back, I noticed the same thing with the needle.
So what I was wondering is whether everyone's needle moves a little bit or if it's just me. I would have thought there is one 'normal' temperature and any movement above it means there's something amiss. Is there something I should be checking? It's not losing any coolant and, as I say, we're talking 2mm here, not journeys up into the red bit.
