Some of you may remember me askin about why my 4WD light doesn't come on a few weeks back, but the 4WD was/is definately working.
Could this be the cause of my problem?
Not the main air intake pipe, the small one that run's underneath it, across the top of the engine block right next to the turbo pipe, and off into the o/s wheel arch somewhere. The bit that run's across the top of the block is metal and where the metal and rubber bit join next to the air intake pipe (where it's arrowed) there's a very small split.
Is there any kind of tape or anything i could use as a temporary repair or to check it? Or if the length is there can i pull it off, cut it back past the split, and reconnect it?
any help much appreciated
