anti roll bushes
  • anti roll bushes
    hi guys just had mot on a 2.4 surf came back fine but got a comment on my anti - roll bushes they are a bit worn is it a big and expensive job to re place them would be grateful for your help and re-plies into the matter
    Milner's do kits for the front and rear anti-sway/roll bars.
    About £12+VAT per kit. One kit for front, one for rear.
    Fairly easy job to do, as well. If you do a search on the
    forum, there are some diagrams somewhere.
      check the links at the bottom of the page
      got mine from toyota main dealer cheap and its a diy job
        Agree with John. I got mine from the TMD at about £12 off the shelf.
        It's only a hobby!
          Yeah, but are they bright orange like Milner's?
            Hi Ian
            My surf failed its MOT on the rear anti roll bar bushes recently.
            It was the D bushes that were worn, they are easy to replace as it is only 4 bolts attached to the axle, but be careful untightening them as i snapped two off and they are a pain to drill out.
            I found the best way to get them out was to untightened a little then tightened again using plenty of WD40.
            Hope this is of some use!
            Neil
            p.s I also replaced the brackets holding the D bushes as well
