How many volts is enough volts to trigger the super glow relay? After having to glow a super glow system for at least 30 seconds before starting I thought somthing was amiss. After stuffing round and checking all the glow plugs, relays, resistors and regulators I found nothing wrong and did it all again. I found that while the glow plugs were still getting power the volts were a little low. This was because the super glow realy was not cutting in but the after glow realy was. The super glow relay is getting power from the timer however it is not enought to trigger the switch. When measured with a multimeter the volts start out at around 10 when the ignition is first turned on but slowly drops away to nothing. I have found out that the super glow relay glow duration is controlled by the temperature sensor in the engine block.
Now for the million dollar question, does the temperature sensor trigger a set switch in the glow timer which breaks a circut to the super glow relay instantly or is it a graduated switch which drops voltage slowly depending on temperature? I am trying to figure out if I have a crook temperature sensor or glow timing unit.
Incase you are wondering, the battery in new and maintains at lest 12 volts even while glowing (afterglow), the model is a 1989 surf LN61 with a 2LT motor and the super glow relay still funtions when run directly off the battery.
Now, after spending 4 hours on this one I am off to bed.
Thanks for all who have a go at this one........
