air con magnetic clutch
  • air con magnetic clutch
    does anyone know what voltage goes into the air con compressor magnetic clutch to get it to work?,the voltage reading down the wire on mine is not very high (i could be precise but i tested it earlier today and forgot but it aint 12 volts,will the clutch kick in if i run it to the battery?) ergo no air con. and has anyone got a diagram of fuses in the cab kick panel as my lid is missing.
    cheers
    cheers
    Yeah, just run a wire to the + on the battery to the plug to prove the clutch works.
      aircon mag clutch
      just hard wired it,spins fine from the battery positive,i'll have to check the rest of the system.
      cheers
