Hi there, I've got a bad noise coming from the top of the engine,the oil pressure is on the low side and all this happend all of a sudden driving on the motor way.Could be the oil pump or the timing belt slipped a tooth? Thanks
noisy engine
depends on what surf you have, but there's a guy on ebay selling engines 2LT and 2LTE £750 buy it now...don't know if thats any use to you.
or ask TonyN he not far from you, he should be able to sort something for you one way or another OR Stevo if you just need new head and then get TonyN to fit it...you never know your luck, get him to look at it may not be as bad as you think.
my engine makes a noise when its running but pretty quiet when turned off...sorryLast edited by logey79; 9 May 2006, 12:02.i swear, it was like that when i got here...
