Rear UJ
  • Rear UJ
    Can anyone help?
    After investigation of some strange noises I found that one of the bearings on the rear UJ (Where it connects to the rear Diff) has shattered. Looking at it, it seems that you have to replace the whole prop shaft as it is welded on (Unlike the other end).
    Is this the case or is there an other way to replace the rear UJ.
    I Have done a search but cannot find anything....
    Thanks in advance
    Marc
    The UJ's are replaced just like any other car. release the C clips, drive them outwards to remove the caps, then pull the yoke from inside.
    No problem.
      Thanks for that
      I will have a good look at it in the morning.
      It looks like the previous owner didn't do any greasing down there so that probably hasn't helped
      Marc
