Hi All,
I was wondering if any of you lot out there have had this problem with the rear window, mine is stuck in the up position, when I put the key in the back lock, and turn it, I can hear the relay click in, but nothing happens, I have tried this with the motor disconnected, but there is no voltage going to the motor, can someone tell me is there an easy way to lower the motor, so I can find this relay box, as I can't open my tailgate with the window up.
Also if it turns out to be the black box, does anyone have any suggestions on where to get a cheaper alternative, other than Toyota, as I thought they were giving me a phone number not the price!
If all else fails I will make something and plumb it in, maybe with a couple of relays and a separate switch, any help would be great, as this has got me a tad stumped.
Could it be just a faulty relay on that little relay board thingy I read about here somewhere, I can't even get to it with the gate locked, or could it be a saftey thingy if it thinks that one of the catches is not closed on the tailgate, something like that???
If it is not sitting in EXACTLY the right spot the window will just give you that blank look as you try to put it down.
