Oil leak!
  • Oil leak!
    Can anybody tell me what this pipe is for? The big grey thing in the left hand corner is the oil filter to try and give a perspective on the photo. It only leaks after a run once the engine is up to temp. Is this common, and is it normally just fixed by replacing the clip with a jubilee one? If I take the pipe off, will all my engine oil pee out all over the road?
    Jez
    __________________________________________
    Hi mate, its the oil return from the turbo bearing. Try a jubilee clip, sometimes the pipe goes hard and splits. You might have to change it.
      Cool, thanks mate, will attack it tomorrow.
      Jez
        You know the number if you have trouble.
          Indeed I do, if an AA tow truck turns up on your doorstep with a burgundy surf on the back again, you know I f*cked it up!!!
          On another note, have you got the recon injectors in yet? How's your stock looking on heated fuel cats aswell?
          Jez
