I have managed to get hold of a dump valve from a Toyota MR2 turbo. i just wanted to know where to plumb the little vacum pipe on the valve into as Diesel turbo engines dont seem to rin a vacum as petrols. I know you can run the dump valves as i have seen them on the Austrailian website and on Mercedes Sprinters of all things.
dump valve ?
Originally posted by christopoher murphyI have managed to get hold of a dump valve from a Toyota MR2 turbo. i just wanted to know where to plumb the little vacum pipe on the valve into as Diesel turbo engines dont seem to rin a vacum as petrols. I know you can run the dump valves as i have seen them on the Austrailian website and on Mercedes Sprinters of all things.
Is your truk an auto? If so this will not be a good idea as you dont shut the throttle between gear shifts in an auto and so a dump valve will be useless.
AlI used to have a surf me!
Use one of the small vacuum lines across top of engine or the one that goes to the vacuum tank. Just install another T piece.Originally posted by christopoher murphyIts a manual 2.4 with a bleed valve running about 10 psi of boost EGR totally removed.
Originally posted by NiftyNevUse one of the small vacuum lines across top of engine or the one that goes to the vacuum tank. Just install another T piece.
Thanks Nev one of the mechanics down the local garage told me i need a solenoid to activate the dump valve is this true or is he spinning me a yarn.
Originally posted by christopoher murphyThanks Nev one of the mechanics down the local garage told me i need a solenoid to activate the dump valve is this true or is he spinning me a yarn.
total bolloks!
Its activated by the vacuum in the system when you lift off the gas.
It it an atmospehric or a recirculating valve?I used to have a surf me!
here you go, if you must make your truck sound like kettle to fit in down McD's.............
http://www.potn.co.uk/-_c5211_6366_p1617000.htm
Your truck takes long enough to spool up at the best of times, believe me, you don't want to depressurise the intake anymore than you have to!4x4toys.co.uk - Keeping you on and off the road...
I have been hitting the deli rolls hard recently, but the website, alas, I found especially for this thread.Originally posted by BUSHWHACKERHow do you know about that website then Tony, d'you go to McDonalds often???
A lifted truck is great down the drive-thro, the other evening my head lights actually shone over the top of some stupid sticker covered Civic. If I got close enough, I almost managed to make him disappear.
Originally posted by TonyNI have been hitting the deli rolls hard recently, but the website, alas, I found especially for this thread.
Thanks tony, gives me the insight to get the beast lifted.
O.K here is my two cents worth.
I had a look at BOV's myself.
I ended up just disabling the throttle butterfly as its only job really was to engage the EGR ( gone ).
I found that with the butterfly locked open I was getting much less turbo lag and it was quicker to come on boost through gear changes.
If you have got a BOV and can be bothered fitting it then great, the effect will be similar.
Let us know how you go.Simon.O.
'90 SSR Ltd 2.4TD 5 spd
Will do simon just waiting for the weekend, have you any instructions on how to lock the butterfly. Chris.
