Are there different pressure ratings on the rad cap I have got a 0.9 but I seem to remember that the original one wot I changed years ago was a higher pressure.I have done the serch bit but failed to find wot I wanted,so I was wondering maybe my memory was playing up again? (its age you know)
Rad caps
Cheers Nev,I thought there was a higher pressure cap but my frail old mind couldnt be 100% sure.And shame on you for thinking that I might be trying to cover up a problemOriginally posted by NiftyNev0.9 is the correct one for the 2.4. There is a 1.1 available that some have used but I don't recommend fitting the higher pressure cap. If you need one then you are just trying to cover up a problem.
Nev
It was more a case of clutching at straws for an easy answer,but I forgot life aint that simpleIf the puddles to deep..LEARN TO SCUBA.
Sorry. I really meant that, rather than cover up a problem, a 1.1 bar cap will not be a cure for a possible problem with the cooling system.Originally posted by sumoAnd shame on you for thinking that I might be trying to cover up a problem
Nev
Nah no need to be sorry m8 its just my quaint pommy humor,thanks for the info.Originally posted by NiftyNevSorry. I really meant that, rather than cover up a problem, a 1.1 bar cap will not be a cure for a possible problem with the cooling system.
NevIf the puddles to deep..LEARN TO SCUBA.
