turbo boost pipe
  • turbo boost pipe
    hello, turbo boost pipe that goes to the switch near the air filter,what does the plastic barrel consist of that clips on to the inlet manifold as i have lost mine and it looks like i will have to make one.
    Which Surf you got????
    Does this help?
    http://www.toyotasurf.asn.au/techsite/turbovacuum.htm
      It's a filter. Should be a similar filter on vacuum line on other side of engine. It stops any little bits of rubbish thet may go through vacuum line and damage the turbo pressure sensor.
        many thanks for that i think i could make one from a fuel filter.
          That would be ok. Stuff a small amount of cotton wool in the turbo pressure sensor side of the filter.
