hello, turbo boost pipe that goes to the switch near the air filter,what does the plastic barrel consist of that clips on to the inlet manifold as i have lost mine and it looks like i will have to make one.
turbo boost pipe
many thanks for that i think i could make one from a fuel filter.Originally posted by NiftyNevIt's a filter. Should be a similar filter on vacuum line on other side of engine. It stops any little bits of rubbish thet may go through vacuum line and damage the turbo pressure sensor.
NevJAP4X4PART ¬ THE BIGGEST SURF BREAKER IN THE UK ¬
