Anyone suggest the cause of this?
I recently had the vehicle serviced and a new water pump fitted at huge expense.
Other day I parked on a hill facing down hill at about 30 degrees and when i came back she had dropped a couple of pints of coolant on the floor.
Got her back home on the drive and no more leak. Filled her up again ant topped the expansion tank up to near the top to be safe.
Looked at the level in the thermostat housing after leaving her to cool and it had gone down a bit so i topped it up. Drove 5 miles and removed the cap to check and its still full.
Just had a peep under her this morning and all is fine.
Why did she drop the 2 pints??????
Al.
Al.
) without disturbing the air-con!!!!
