Cooling system hoses
  • Cooling system hoses
    If any one can help, I'd like to find out the part numbers for all the cooling system hoses for my surf 91 D/T 2.4lt, import... I live in Australia and unless i go to Toyota which will cost $340au dolars for 6 hoses, i would rather look else where. Unless i can get them posted to Australia....
    Thanks to all that help....
    This might help. http://toyotasurf.asn.au/forum/viewtopic.php?t=881
      Went to link of Surf Australia
      Went to look at the link, there is no display availible for radiator hoses.
      I'm still looking around..
      Thanks anyway...
        Thanks anyway...
        From posted link -
        16571-54310 (top) specific to the 2LT#
        16572-54270 (side) same as aussie 2L/3L (as in motor not litres)
        16572-54081 (little one below the radiator) same as 3L (motor)
        Which hoses do you require. There are more than six.Most will be genuine Toyota.
          Re: Hoses
          Thanks Nev,
          I would like to replace all 6 six hoses,the one's around the front of engine and maybe the heater hoses. I was told that some of the hoses have to purchased from Toyota and othes from any auto shop. I just need the parts number..
          Thanks for the main hoses part numbers, a great help...
            I don't have all the part numbers for the Turbo Heater and Manifold hoses. There are also different hoses across front of engine depending on if you do or do not have a rear heater.
