when cold, my gears seem a little "lazy". had to reverse first thing this morn, beeper sounding but no reverse drive, also, there is a short, very steep hill i go down after leaving home, when i reach junction at bottom, (on the flat), i go to pull off and it revs for a split second as if it builds up pressure b4 moving off ????after 2 mins running , all is ok...... is this symptoms of low fluid level, or, oil needs changing ??? where do you put oil to top up ??
anybody in s.wales able to flush and change fluid for me ??
there is NO lock up, as engine revs freely until truck moves off.....
cheers....... CARL........
