Hi, this week as soon as the car heats up the windscreen mists and is impossible to keep clear.
I also noticed a smell of antifreeze.
After doing a search i have now looked under the centre dash and i can clearly see coolant on the side adjusters on the drivers side and on the floor.
Does this mean that the heater matrix has gone, or could it possibly be a pipe leaking or where the pipe joins the matrix.
Is there any way of testing this without taking the dash apart.
If the matrix has gone, where is the best place to get a replacement, and would i be better off getting someone else to do the job as from reading a lot of posts is is a bit of a fiddely job.
For the time being though, if i turn the heat settings on the dash to cool, will this stop the leaking for the time being.
And can i leave the rear heater on or will i also have to have this on cold setting.
Thanks for any help or advice
