Hi
Right, this is gonna be difficult to explain so please bear with me!!
The truck is vibrating excessivly - at tickover its normal - feels fine, the vibration starts at about 1250rpm gets to its worst at 1500rpm, eases off at 1750rpm and has gone by 2000rpm. Anything above this is fine.
It is not speed related, it the same if I put it in park or neutral.
When driving it feels as if its the engine vibrating, as if its not bolted to the chassis securly, when I got home last night I had the bonnet up and her in doors on the accellarator. When doing this it sounded like it was coming from underneath the truck rather than the engine bay, somewhere between the engine and transmission.
The vibration is that bad it makes the rear view miror and steering wheel vibrate like you wouldn't believe (she was getting quite excited in the drivers seat!
I am thinking it could be a UJ in the propshaft??
any other sugestions as to what to look for / tighten / replace are appreciated - I will be having a goos look at it on Sunday!
Many Thanks
Joe
) I am thinking it could be a UJ in the propshaft??
Many Thanks
Joe
