Hi all
you guessed it, this is another one of those "inexplicable grind" sort of posts. but I get the feeling this one won't be remedied with the odd blob of vaseline.
If my surf's been parked overnight, or for any considerable amount of time, whenever I start driving this grating, grinding noise soinds from the front. You can feel the low vibrations in the footwells of both driver and passenger sides. The noise stops as soon as the brakes are applied, but more often than not starts again a few moments later.
The noise stops completely after I've driven a few miles or so, only to return next time I start her up.
It doesn't seem to be related to speed, wheel turn etc.
I've had the front wheels off, checked the brakes, cleaned everything in sight and STILL it happens.
It seems totally random, completely intermittent and thoroughly annoying.
Help
Help
