Guys,
Possible problems on the way home from work yesterday (15min drive).
The temperature on the truck (93 Kreg 2.4td) started swinging up then dropping back to half way. Stopped the truck then let it cool down, restarted and got it home without going into red. When I got out the truck, there was a large pool of coolant underneath. I have been checking the level in the overflow chamber and it has been staedy. When I re-checked it after stopping, the coolant in the overflow chamber was still at a normal level but it was too dark to tell if there was oil in it or not.
I had the coolant system flushed a couple of months back and the thermostat and radiator cap renewed at the same time.
I am hoping this is not the dreaded cylinder head problem.
I need to refill the system before re-starting the engine, to check all the hoses, radiator etc. I may sound like a dumbass but I assume I re-fill the system through the radiator cap on the thermostat housing? Does the heater need to be on to allow the thermostat to open to fill the system? How do I know what the correct level should be, as any car I have had before has had the cap actually on the radiator and you could see the level.
Any help would be appreciated.
