Airlock Huh...
  • Airlock Huh...
    OK - Suspected airlock due to the temp gauge winging up and down at will with engine fan coming on. No heat through heater when this happens either. So ive got an airlock.
    Anyone got a simple method for curing this little gem!
    Any thanks gretaly appreciated....
    piece of cake, mate!
    http://www.yotasurf.co.uk/forums/sho...ht=Bleed+Valve
    that should do it, failing that try a search on burping! yes, really!
    it's in me shed, mate.
      Turn All Fans Onto Hot And Full Power.....now Take Of The Filler Cap For The Water And Leave The Engine Running Till The Thermostat Opens,,when It Open All The Bubble Should Start Coming Out,keep Filling With Water Till The Bubbles Disapear...
        just to say you will probably have to rev the car - my stat will not open idling.
        Tim
          If you have a seperate fan in the rear don't forget to turn that one on as it hasit has its own pipework and matrix
          www.daemon4x4.org
            No need to turn fans on. You only need to open heater valves. You want it to heat up as quickly as posssible so turning on fans only helps to cool things down.
              Nice one people - really appreciate the advice - topped it up this morning with heaters open and 8 yr old revving the engine and drove it to work - No temp fluctuating! First time!!! If it was a head prob would the temp gauge still be all over the place regardless of what i did to the rad?
              You can tell what im worried about eh!
                Don't worry. It looks like you have fixed it. Easy innit?
                If the head was gone it would spew the water out of header tank from cold.
                It's only a hobby!
                  kitesurfphil,,that is not completely true,,my head was blown but as the stat was not open for my short journey the water stayed in the engine (well some out the exhaust) but when the stat opened it blew out hard....there ya go new head no probs now yay but hey your fix seams to sound good
                    I stand corrected, Sir! I guess it depends where the crack in the head is. I have had airlocks a couple of time. Which reminds me ...........I must check the coolant level today.
                    It's only a hobby!
                      lol
                      your not corrected ,,just helping,,i checked my level's after reading your post so thanks for the reminder lol ::P
                        Nice one people - all ok and able to just enjoy it now. Will prob be back soon when i next need advice...
