Right after changing my thermostat and pressure cap,
and testing the coolant system, all seemed fine.
Well for about a week.
Just stripped the head off and is deffinately cracked.
I am would like to know is what you guys think I should do.
Should I replace the head, with one of the modified ones. Only trouble is there seems to be a fair bit of corrosion around the top bores on the block.
Will get a pic on monday to show how bad. You guys may think its fine.
OR
Do I attempt to find a 3.0l td and fit that. Will want a manual though, even though mine is an auto at the mo.
Any advice you guys can give will be much appreciated. Also what type of price would I be looking at for the engine, gearbox, loom and ecu.
Had thought about getting a crashed 3.0l manual and taking all the bits i need.
Not sure which would be better and more cost effective.
Thanks
Dan
OR
Thanks
Dan
