Hello, just wondering about charging the batteries on my surf, is it ok to do it with both connected, or should i disconnect and do them one at a time? Also the water temp guage isnt working, so i looked under the bonnet and there appears to be 2 connections and one seems to be snapped off, if someone could send me some info on the correct setup i would be very grateful, Cheers, James
Battery charging and water temp guage
Originally posted by jcuff86Hello, just wondering about charging the batteries on my surf, is it ok to do it with both connected, or should i disconnect and do them one at a time? Also the water temp guage isnt working, so i looked under the bonnet and there appears to be 2 connections and one seems to be snapped off, if someone could send me some info on the correct setup i would be very grateful, Cheers, James
Also the mast on my surf is broken and i need to replace it. Does anyone no how this is done? cheers, James
