hello people
i have a 2.4 1993 surf i had the termo stat, water pump, t-belt, rad cap all changed a couple of months ago as well as a presure test and everything was ok, i now have a coolant leak it drips down both sides of the bottom of the engine when idling, or stopped or turned off after a run, it's ok when driving. i have no white smoke no oily water no temp rise all normal, if it's a leaky or loose pipe where and what do i look for. if it's not, any words from the wise would be a big advantage.
thanks in advance
paul b
(not mechanicaly very minded)
thanks in advance
paul b
