Any other surfers experienced a weep of oil at the base of the cylinder head ?. Reckon this is the cause of the drips onto my drive.
Can be seen on passenger side front at around the same level as the top of the fuel pump. Always thought it was where I spilt oil during service but appears to fizz a little when you rev the engine.
No other cylinder head symptoms so am hoping this is just a leaky oil path. Thoughts ?. If it is an early symptom of soething then would rather tackle now before it gets expensive.
