does anyone know how to remove the dipstick pipe,is it bolted in or pressed home and if its pressed how can it be removed and put back?the problem is that it seems to have been bent to such a degree that on removing the dipstick it wont go back in,have tried ti straighten it and squeeze the bend out at the bottom but still no joy.any ideas??? 1993 2.4,Cheers
Dipstick
Originally posted by whirly03if i remember correctly its bolted on just under the fuel rail,,,,i think,,,
it looks like a nut on the bottom of the pipe but its a sod to get at,was hoping to be able to get at it without removeing anything but dont look like thats going to be possible,was just hoping to see if anyone knew before i tried to undo the nut(if thats what is holding it on),didnt want to force it and break it off completley
Strange init, non-EFI 2.4's and 3.0's are just a O-ring that pushes in the block, but the EFI ones are bolted in?Originally posted by whirly03yep that nut is correct,its a pig to get out aye
