Hi all,
Recently while offroad, I had the same problem several times while engaging my 4x4. I have a Hilux Surf 2.4 91 model. While stopped on the sand I would press the 4x4 button and none of the wheels would move at all until I would push the 4x4 lever into the L position manually. However if I turn on the 4x4 while moving I experienced no problems. I also noticed that on slight inclines the 4x4 would struggle to get the car forward on the loose sand and the tyres simply will not spin. Is there some problem with the transmission?
