Head Problems
  • Head Problems
    Hi There All
    Well I took the plunge and bought a 2.4SSRX with a 'blown headgasket'.
    I'm doing all the work myself. A mate is giving a hand when he can. The question I have Is how do I know if it is a gasket or a cracked head. Here as some pics to have a look at.The first pic is of cylinder no4 the worst. I'm worried about the corrosion on the sleeve. This is were the injector sits.(When I removed the head the top of the piston was brown indicating water??) The second is of the headgasket.
    The truck stood for about 5 days before I drained the oil. At first I had water comming out of the sump then oil. I'm guestamating about 1-2 liters of water.
    Thanks a Mil foryour help
    Looking at that head gaket id say you got a cracked head as there is no sign of blow past from the water journal into the bore
      2.4 cracked head
      i had a problem with my 2.4 surf when it overheated in the summer but since then it has been ok. a couple of weeks ago i had it antifreezed and a couple of days later it blew it out of the exhaust and that was that ! i have had the head taken off and guess what the head is cracked and no4 is the worst. sounds like it could be the same as yours. i have ordered a head from stevo because everybody recomends him a modified head will cost you £799 which includes all gaskets bolts belts etc so sounds like the way to go.
      hope it helps. mine is a 1992 (j) 2.4 ssrx approx 63000 miles.
      it's a blue 2.4 litre diesel monster
        head
        The corrosion around the top of the cylinders is a sure sign of a cracked head, post some pics of the head, try to close up on the valve area's.
        Cheers, Steve.
          Like this one!
            I bought a surf VERY cheap with blown head. Three heads later and about to fit THIRD engine it was originally the block! (second engine was second-hand with problems too) BE CAREFULL!
            Good luck though.
              Good luck though.
              Yeah I think I'll stick to new if possible
                Pic 3 certainly looks like it's got a crack showing between the valves.
                Mike G
                  Head Problems -Repair Inprogress
                  HI All
                  Well I've recieved my new head from Stevo Today. I'm busy re-assy the new head.
                  Had to convert the Kitchen into a workshop as the weather is absolutely S-H-one-T out.
                  Thanks and many PRAISES to Stevo for his help and the rest of you guys for all the input. Thanks again. Dev
                    no doubt about it that head is ****ed....look between the valves big cracks also the pe combustion chambers are all cracked,,,sry to be the beareer of bad news but get a new one
                      He did,
                      now that you know everything RSA, whats a precup actually do. Whats a swirl chamber for?
                      I dont know.
                        Originally posted by JimL
                        He did,
                        I dont know.
                        a pre-cup is the one below a AA bra... and a swirl chamber is something you should have watched a video about at school.
                          Pre-Cup
                          Jiml I think you must be talking about Rugby No??? HaHa
