Whenever it rains hard water comes in from somewhere around the top of the back window. Anyone had this problem? Any ideas how to fix it?
Rear Window Leak.
Originally posted by And_oWhenever it rains hard water comes in from somewhere around the top of the back window. Anyone had this problem? Any ideas how to fix it?
would check wiper & water washer mounts to make sure they are tight and clean.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
I Had A Car Once That Did The Same Thing. It Turned Out To Be Nothing To Do With The Window It Was The Seal That Goes Round The Sunroof. The Water Was Leaking In Through There And Running Down To The Back This Made It Seem As Though It Was The Window.
If You Have One Check The Runners That It Slides Along For Water After It Rains. Failing This Get Someone With A Hose Pipe And You Sit Inside And Look For Where It Is Coming In.
Hope This Helps
