Full service
  • Full service
    I need to do a full service on my 91 surf, I am getting the cambelt changed next week but everything else is down to me..any guides on what i need to do?
    Keep it greasey so it'll go down easy...
    Type "Service" into the search option. Everything you need to know is available on here.
    Mike G
      Service
      Ok will do
        Service
        Dude, I can't find service info anywhere, I have come across other service info before, but do you think I can find it when I need it...problem is there are hundreds of posts that include the word "service"...lol
          just the normal things oil / air /fuel filters / oil then
          check the other fluids auto box oil / dif levels the list goes
          on to your wishes me old m8
          your filter kits either Rough trax or Milners come as a set.
          poppy
          GOT NO COWBOYS HERE?
            Order Filter Kit from milners [Oil, Air and Fuel filter] about £15 + delivery
            10w/40 engine oil will do.
            OIL
            Run the engine for a little while to get the oil running. Undo the nut and drain into a BIG bucket as the engine will require 6.5 to 7.5 litres depending on removal of Oil filter.
            This running of engine should also loosen the Oil filter a little. Use strap or chain to unwind [oil will still be inside filter so be careful]
            Replace new Oil filter by hand after running some new oil around the seal and tighten [once resistance tighten a little further by hand]
            Fill back up with oil, monitoring dipstick for level
            Discard of oil safely [should be taken down to your local tip for disposal]. Use an old oil botle or one of the empty plastic cans you can buy for this purpose.
            FUEL
            Have bucket ready to remove Fuel filter.
            Disconnect wire to bottom of Filter from connector [normally on the wing]
            Remove filter clockwise if remember correctly???[believe same as 3.0 models] using Filter Chain or Strap
            After removal of filter, unwind the plastic cap [includes drain tap] using filter chain or strap [be careful not to damage it] and pour diesel into bucket
            Screw back onto new Fuel filter after running a little of old diesel around seal using finger, attach filter back to filter housing, remove the Pipe marked out and pump the filter to draw fuel through. Re-attach the line once fuel drawn through. Keep pumping till the pump gets hard
            Start engine and keep checking pump once again [engine off].
            Dispose of diesel from filter safely
            AIR FILTER
            Remove Air sensor from side of filter
            Remove catches from filter housing [normally three] and lift up the lid carefully. Replace filter lid fasten back up and re-insert sensor.
            Gaz
              U d man
              Thanks Gizmo u d man...
                Nipples
                Any idea on gease nipples, came across something on here once that said there were a bunch that need greasing regularly...
                  have a look on the sun visor, it'll probably be in japanese but the pictures should make sense (i think translations are source-able on here) basicly on all propshaft joints, if you see a nipple, grease it!
                  Diesel, like petrol only better
                    Nipples
                    Cheers, is there any preference on grease?
