'92 Surf SSR-X
2.4 Diesel
2 batteries
My heater has been on the blink this past week, only getting slight heat through once the engine has warmed up. Haynes manual suggests flush the radiator if it's looking a bit gunky (which it is) as a first port of call.
Set off driving back home last night, enginge started OK and running fine. Heater was switched on and blower was running on "Low" setting. As soon as I started to pick up speed there was an odd smell, kind of burning but couldn't place what it might be. I wasn't sure if it was me or the car in front, but I turned the heater and blower off in case - the smell went after a minute or so and the car in front had gone so I assumed it was the other car. Turned the heater back on a little later and there was no smell.
When I got back home I checked under the bonnet to be sure. Although the smell wasn't strong it became apparant that it had been my car that had produced it. Seemed to be coming from around the radiator area. It was really dark and 11pm at this time so decided to wait till this morning to investigate.
Just had a look under the bonnet - all the drive belts look OK, fan is turning, battery levels read OK on the gauge, and the coolant is looking a bit grubby (as I said before). The other thing that looked out of the ordinary was a trace of mystery liquid along the side of the battery. See pic below ...
I know it definately wasn't there last weekend when I was topping up screenwash so it's happened sometime after then. I couldn't work out if the liquid had leaked from the battery or had been splashed onto it by one of the belts. The liquid is crusty to the touch but I'm not sure if it's just because it's so cold today and it's frozen.
Can any one confirm/suggest alternatives to my inept diagnosis?
1) Smell is due to raditor getting too hot due to poor coolant circulation?
2) Smell is due to battery leaking / mystery liquid?
3) Heater is on the blink due to poor coolant circulation?
4) Battery needs replacing - it's leaking electrolyte?
I wish it was possible to post smells on here too! Hah hah
****UPDATE!*****
After a bit more looking (and smelling) I've tracked the smell down to the driver-side battery itself. Any ideas? If getting a new battery's part of the solution, is the spec 12V and 380CCA for the two battery version? All the writing on the batteries is in Japanese (apart from the 12V bit) so I'm clueless.
John
2.4 Diesel
2 batteries
****UPDATE!*****
John
