hi all, i'm in the proccess of replaceing the heater matrix. all was fine until i connected the clocks back up and checked the opperation of the fans/vents.
the handbrake light wont go out on the dashboard. i've checked the fluid level and float, not sticking, connected/disconnected - o.k, have had the handbrake switch off, stipped it, shorted it, ajusted it, tested it-o.k, pumped brakes and fired up engine to check for vacume-o.k.
only thing i can think of is that i've disturbed a wire somewhere and it's shorting out. dont want to remove dashboard again (those who have done it will understand why!!) failing that, i'm gonna take bulb out of clocks!!
any more ideas?
andy crofts
p.s. dont be fooled into thinking the heater matrix repiar is a simple one, i've been at it for two days now and the car still looks like a breaker iinside!!
any more ideas?
andy crofts
