hi 2.4 ssrx when its in traffic ie stationary the electric fan comes on and the temp guage goes up to red,its not the coolant i've checked tha rad seems fine and working what the **** is it the ****ing thing is ****ing me off.
apart from the shes a lovely beast and i love her.x
cheers for any help given great site too.x
Im sorry to say you might have a busted head. From cold try running it with the rad cap off and see if it overflows straight away.
Try a new rad cap and stat as first ports of call.
Have you tried opening the heater controls fully and running up from cold with the rad cap off? Rev the engine from the throttle linkage and watch the level. I had the same syptoms recently, caused by an airlock in the coolant. Also check to see if your viscous fan is locking when hot. When cold you can stop it quite easily with a rolled up newspaper. When hot it will bend the paper.Have a look in the FAQs bit for "Burping the cooling system."
I have never found it necessary to rig up the funnel, only to keep topping up as I see the level drop.
