Been looking around for an oilcatchcan and figured that it was easier to make one.
This was easy and simple, used an old AirCon filter/drier got a lathman to cut it open at the top and then put in a few threads, welded a small piece of flat iron to mount this next to the brake servo (truck is auto, no clutch). Also shortened the input side pipe and retained one perforrated disc to hold the steel kitchen scrubber at the bottom. Total cost $4. Will post some pics once it is painted and mounted. Attached are some pics:-
