Hi everyone,
i am on here for a friend who owns a 92 2.4 surf. we have had the usual cylinder head woes. cracked across all four cylinders between the valves. managed to find a good cylinder head which could possibly be a modified one. replaced this and checked everything out. filled up the system, using an old 2 litre coke bottle as extended header for filler. kept fluid above height of both heaters, put both on hot, had front of vehicle higher than rest of vehicle to aid bleeding of air. done all this, everything fine, all getting hot, running perfect. the radiator has been repaired and cleaned out, the cooling system all flushed to clear **** out. took vehicle on long test drive all ok. friend took it out, did bout 40 miles and it shot into red, lost all water.
checked it over, found rad cap not brilliant so replaced with new one of correct type/rating. rebled system, checked out and i took for long run. did 60 mile run various speeds and engine speeds. heaters all blowing hot, viscous fan all working ok, extra cooling fan working ok. re-checked level all ok expansion tank level fine. decided to use vehicle once more to thoroughly check, did about another 60 mile, the temp shot into red, electric fan running to try cool system, steam poured out, and blew cap off expansion tank. system lost all water.
got RAC out they refilled, visual check of flow in filler, all seems good and ok, drove home bout 10 miles, with him following, the guage stayed bout halfway between half and quarter.
totally baffled now, head not cracked, gasket obviously not blown as is pressed steel type. anyone with any ideas cause im at wits end, and mate getting pssed off cause he cant use his surf.
cheers for now
keith
cheers for now
keith
